ArunGupta's avatar
ArunGupta
Apprentice
Dec 25, 2022
WiFi 6E speed slow
I have the RBKE 960 main router connected directly to Verizon Gigabit ethernet cable. At the Verizon cable, I am getting 900/900 download/upload speed. However, connected to WiFi 6E, I barely exceed 400-500 Mbps download even when I am like 4 feet away from the router in open air, nothing else connected, either to WiFi or wired.
Recently, I had gone to my son's place. He also has Verizon Gigabit connection and uses Verizon supplied 6E router. I connected to his 6E network and easily got 850 Mbps download speed even when his router is in the closet and I was 10 feet away.
In both cases, I am measuring the WiFi 6E speed using my Samsung Galaxy S22 Ultra phone using Ookla speedtest app.
Why am I getting such poor download speed with Netgear which is the most expensive 6E mesh system today?
  • plemans's avatar
    What speeds do you get with a pc/laptop hardwired into the orbi?
    Verizon is great at supplying modem/router combo gateways. they can cause a double nat.
    A double nat happens when you cascade more than 1 router. Potentially your son might have it setup in the correct configuration.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
    • ArunGupta's avatar
      ArunGupta
      Apprentice
      a) The hardwired speed at Orbi Ethernet port is 900/900 so it is the WiFi which has poor performance
      b) Verizon does not have a separate modem. They have given me a Ethernet cable right from their ONT, so there is no question of double NAT.
