Orbi WiFi 7 RBE973
Reply
adding a RBR350 as a third satellite
brentoss99
I recently brought a Orbi AX1800 WiFi 6 Dual-band Mesh Router with 2 satellites for my home. I've found a used RBR350 could i use this as an additional satellite to extend the reach of my network?
Message 1 of 5
Guru
Re: adding a RBR350 as a third satellite
AX1800 is a sped, not a model. what actual model did you buy?
Message 2 of 5
brentoss99
hi the model i brought was a Orbi 6 RBR350 1x Router & 2 satellites do you need any further details?
Message 3 of 5
Guru
For the orbi's, the RBR's are the router and can't be used as a satellite. If you had a used RBS, you'd be fine.
Message 4 of 5
brentoss99
ok thanks for the advice
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1825 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
