TomWarner97
May 12, 2024Aspirant
orbi satellites won't connecting to each other - ORBI RBR760
Hi all,
I can't figure out to get my satellites to connect to each other.
My router is downstairs.
1 satellite is on the first floor and 1 on the second floor.
The orbi on the second floor won't connect to my satellite, but it connects directly to the router.
How can I fix this?
Because I'm losing a lot of speed through this.
How does the Orbi web interface Attached Devices display report the status of the two satellites?
(5G or 2.4G? "Good", "Fair", "Poor"?)
Sometimes moving the satellites around a bit improves the signal strength and changes how they connect.
Houses have so many things "hidden" inside the walls and ceilings that may interfere with the radio signals.
I would recommend powering off both satellites, then powering up the first and let it settle down before powering up the second.
It might be faster directly connected to the router then hopping through the satellite.
Just because its closer to the satellite doesn't mean it has a better connection or faster speeds.
The orbi's have some sort of internal test (that I have no idea how they determine) whether it connects to the router or satellites and isn't user changeable. The older generation devices you could disable daisy chain but you could never force it.
- TomWarner97Aspirant
I lose speed when i direct connect to the router. I want 5ghz but it keeps on 2.4ghz. Even if I turned it off.
They both give 2.4ghz with a green connection. But the problem is that my orbi doesnt connect to the other one. So now i only got 40mbs top
Thank you for checking. Is this on the web interface Attached Devices or on the Orbi 'app'?
This is what my Attached Devices Connection Status looks like:
If the satellites are connected at 2.4G, that is the problem. (not which unit they have connected to).
Building materials appear to be interfering with the WiFi link between orbi units. Either they are too far apart, or the material between them is too dense for WiFi to penetrate.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Any Wifi Neighbors near by? If so, how many?- FURRYe38Guru - Experienced User
