Orbi WiFi 7 RBE973
Reply
utt er840g vpn router with Orbi rbr750
Nub2
Follower
Has anyone configured the utt er840g vpn router with Orbi rbr750?
I am trying to use a primary and backup ISP managed by the utt and broadcasted on my Orbi mesh system. Thanks in advance for your help!
Message 1 of 2
Guru
Re: utt er840g vpn router with Orbi rbr750
Haven't seen anyone here with that model router. Might go over to that mfrs forums and as there.
Have a router in front of the RBR750 if you run the RBR in router mode would be a double NAT condition.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 737 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
