× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
AC Power adapter Orbi RBK353
Misquet
Tutor
Hi,
I need a AC Power Charger for the Orbi RBK353 (Europe/Holland Version).
I assume you can also use universal chargers however I am not sure which type?
Can you please help?
Thanks a lot
Message 1 of 9
Accepted Solutions
Guru
Re: AC Power adapter Orbi RBK353
According to the manual:
North America: 120V, 60 Hz, input
UK, Australia: 240V, 50 Hz, input
Europe: 230V, 50 Hz, input
All regions (output): 12V, 3.5A DC output
So you'd want a 3rd party supply with a 12v 3.5amp output.
Message 4 of 9
All Replies
Guru
yes you can use a 3rd party power supply. You just have to make sure it has the same voltage and polarity output as the original. It can have higher amperage but not lower.
Message 2 of 9
Misquet
Tutor
Thanks for you're help.
Do you perhaps have suggestions?
I have bought a set of 3 without the power supply (not shipped / received yet) and want to order however not sure which one to order?
Message 3 of 9
Guru
Message 4 of 9
Misquet
Tutor
Thank you so much.. I really appreciate it. Do you perhaps also know what the diameter is of the connector?
Message 5 of 9
Guru
I don't. Sorry!
the specs don't show it and I don't have one.
Tried looking up the fcc info but didn't find it in a language I could read 🙂
Message 6 of 9
Misquet
Tutor
Thanks
Perhaps someone who owns an orbi can tell the diameter of the RBK353 connector
Message 7 of 9
Guru
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Message 8 of 9
See my other answer to this question which, thanks to bad advice from someone else, now appear several times.
Orbi Rbk 353 - NETGEAR Communities
As I suggested there, look for an adapter with swappable tips.
There is nothing special about Orbi devices. Same sort of adapter as  Nighthawk stuff, switches even. If you have one of those, the tip will almost certainly be the same size. I've tried them.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2041 views
  • 6 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
