contenderv07
Feb 06, 2020Aspirant
BGW210 ATT Fiber
Hey everyone, I just got an AC3000 and 2 satellites and I'm having some trouble getting connected. I informed ATT that I was moving from their wireless to the Orbi, and they said they would make changes. They told me to wait an hour and then to reboot. I have done that and the Orbi's still weren't working so I decided to log in to the router and take a look. It didn't seem like they did anything since passthrough was not enabled. I tried going through this thread (https://community.netgear.com/t5/Orbi/Orbi-with-BGW210/m-p/1721982#M55705) to see if there was anything else I needed to do.
Are there any additional steps? or are all of them in the link above? Thanks again for any info
Ensure you try one of the options listed since your ISP service HW has built in router:
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- contenderv07Aspirant
thank you for the response.. I am on the latest firmware version (updated it with support). I have disabled all of the wifi radios on the ATT router. I'm at work but will check it out whne I get home. Thanks for the response!
Latest being v2.5.1.8? Just making sure.
- chiadisanAspirant
Hi,
I'll be setting up a friend's Orbi with AT&T gateway tomorrow. I have one also. I've seen so many variants re: setup on this site so, I'll keep this simple.
*My setup at home is the att gateway BGW210 with WAP for U-VerseTV (IPTV). Orbi is plugged into gateway, of course, WAP is plugged into the gateway, works fine, never has any issues seen in other threads. orbi was always in Router mode. NO issues, other than TV stutters or freezes sometime, they all do *However, as a test, I did just leave the att gateway as-is and put the orbi into AP mode, all seems fine - though it was fine *before doing this.
Just looking a simple setup solution when doing my friend's same setup tomorrow. Am I missing a step re: gateway passthrough, etc?
Thanks!
I would review this:
chiadisan wrote:Hi,
Thanks!
- chiadisanAspirant
Thanks,
I have the native Ookla speed test app. My fiber 300 is about 370 up and down (ethernet) and near 200+ on Orbi WiFI.
Changing the Orbi to AP from Router hasn't afected speed - or anything esle.
