Orbi WiFi 7 RBE973
Reply
Can I user Orbi AC3000 WiFi with my own router?
argold
Guide
I want to enjoy benefits of Orbi AC 3000 mesh WiFi but without using the Orbi router (because I need to use a router with dual WAN). How? Do I buy a regular router pack (RBK53?) and then ignore router setup, disable its DHCP and connect my Draytek Vigor router to a gigabit LAN port of the Orbi router? Advice or suggestions or reports of success with such a setup will be appreciated.
Message 1 of 4
Accepted Solutions
st_shaw
Master
Re: Can I user Orbi AC3000 WiFi with my own router?
Easily done! Just connect the Orbi "router" to your Draytek (on the LAN side) and configure Orbi to operate in Access Point mode. I run my Orbi in AP mode behind a Mikrotik router. Before that I ran it in AP mode behind a Cradlepoint router, with dual WAN.
Message 3 of 4
All Replies
Hydro130
Luminary
That's not possible with Orbi, but this new extender is designed exactly for what you are talking about.
Message 2 of 4
st_shaw
Master
Message 3 of 4
argold
Guide
Thank you.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3453 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
