- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can an Orbi function of another router's Lan port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can I just run a line from one of the ISP Router's LAN output ports to the Orbi's Internet (yellow) port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can an Orbi function of another router's Lan port?
Yes.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
