× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Can not update RBS50 or RBR50 firmware
bcrooks
Tutor
Hello all -
I have been trying to update my firmware for days. I feel like I am about to loose my mind.
I have followed the instructions I found in this community here: https://community.netgear.com/t5/General-WiFi-Routers-Non/Orbi-Router-Firmware-RBR50-won-t-update-bu...
Like the poster above, my firmware is also version V2.1.4.16_1.0.0.11.
No matter what version of the firmware file I upload I keep getting the same message:
"This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I have tried 9 different firmware versions starting with the one right after the version I have then moving sequentially one version at a time forward.
Am I doing something wrong?
I am on a mac. I download the zip. I extract the zip and upload the .img file. And then upload it here (see below). Am I missing some basic action?? What am I doing incorrectly?
Thank you for your help!!
Message 1 of 10
Accepted Solutions
Guru
Re: Can not update RBS50 or RBR50 firmware
Thats because you have a Verizon branded Orbi system. Verizon did there own FW for Orbi hard ware and thus put forth there own Orbi system using there FW. You'll need to contact Verizon for there help and support regarding FW updates they developed.
Message 3 of 10
All Replies
bcrooks
Tutor
Oh... and to clarify, I am getting the firmware versions from here: https://www.netgear.com/support/download/?model=RBS50
That is the product page i get when I search up my serial number so I am pretty confident those are the right firmware docs.
Message 2 of 10
Guru
Message 3 of 10
bcrooks
Tutor
Ugh... Of course they did. Well, at least I am not loosing my mind.
Thank you!
Message 4 of 10
Guru
Message 5 of 10
Brandon_Mc
Initiate
Hi, I having the exact same issue, where did you get the correct firmware from?
Message 6 of 10
Brandon_Mc
Initiate
When I contacted verizon nobody knew what I was talking about.
Message 7 of 10
bcrooks
Tutor
Per what  FURRYe38 wrote above... My Orbi (and it sounds like yours) is a VERIZON branded orbi. And as such, it has VERIZON firmware, NOT netgear firmware. So in short, we cant update the firmware with Orbi firmware.
I also contacted Verizon and like your experience, they were equally as unhelpful.
I was reading on another forum about someone else who was dealing with the same thing. Basically, if it aint broke don't fix it. Since the Orbi was working, that person just stopped trying to update the firm ware.
Which is basically the stance I am now going to be taking. Not the one I want to take. But am not really seeing an alternative at this point.
However, if you find out how to update it, please share!!!
Best
Message 8 of 10
bcrooks
Tutor
Oh... here is the link to the thread I found on verizons forum...
https://forums.verizon.com/t5/fios-internet/how-to-update-firmware-on-verizon-branded-orbi/td-p/9073...
Its basically circular reasoning...
Message 9 of 10
Guru
Top Contributors
Discussion stats
  • 9 replies
  • 2623 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
