- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot reconnect Satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
I've a problem trying to reconnect a Orbi Satellite.
I've also try the factory reset of the Satellite, but after reconnect it to the network, on web page I've the satellite in DISCONNECTED status, with REMOVE botton.
What I've to do, for reconnect it to my Orbi network?
I've a RBR50 and 3 RBS50. 2 of this working fine, only 1 doesn't reconnect (previously it work fine but, several week ago, the device attached to it don't connect to network).
Thanks and regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot reconnect Satellite
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Whats the placement layout of the satellites from the RBR?
Turn off all other satellites and then try to connect the one. Move the satellite in the sam room as the RBR to see if it connects there.
Is Daisy Chain Enabled?
Ensure all satellites are on the same version of FW as the RBR.
@MatCas71 wrote:
Hi all,
Thanks and regards
