× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Connected Device change from extender to router
Mm806
I have a Roku that is connected to the orbi satellite but I would like to connect it to the router wirelessly. Is this possible? If so how? My roku does not have a wired connection by the way
Message 1 of 7
Accepted Solutions
CrimpOn
Guru
Re: Connected Device change from extender to router
@Mm806 wrote:
Sorry by extender I meant satellite. A router does not send out a Wi-Fi signal ? How do I connect to my router wirelessly
Orbi routers and satellites broadcast exactly the same WiFi name (SSID) on both 2.4G and 5G WiFi channels.
WiFi devices include networking software which examines the signal from every available access point (router, satellites, neighbors), ranks them somehow, and chooses one to connect with. When it already "knows" the WiFi password and is set to "connect automatically", it just does it.
Does the Roku not perform correctly?
Message 6 of 7
All Replies
CrimpOn
Guru
When the Roku device goes through the network setup, it choose the most desirable WiFi connection.  The router and satellite have no control over which access point the Roku chooses.
Message 2 of 7
Mm806
If I disconnected the extender completely left the router on and ran the roku set up would it then connect to it?
Message 3 of 7
CrimpOn
Guru
Extender can have multiple meanings.
  • If the Roku connected to an Orbi satellite, then I doubt anything would change.
  • If the Roku is connected to a "WiFi Extender" (not to a satellite), then it might.
Message 4 of 7
Mm806
Message 5 of 7
CrimpOn
Guru
Message 6 of 7
Mm806
I just wanted a stronger signal for my roku. I u plugged satellite and restarted roku and it automatically connected to the main router 👍🏽
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1263 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
