Orbi WiFi 7 RBE973
Reply
DHCP leases not persistant after restart
NetworkEng
I work with IP set top boxes, home networks, etc.  Recently I upgraded a MoCA based network that had individual access points to Orbi hoping to take advantage of a mesh network.  Unfortunately I've run into a number of stability issues which I think may be impacting a lot of other users based on several threads I have run across.  I am running the latest v2.2.1.210 and I haven't used any other versions.
 Every time the router restarts when I apply a change, reboot, etc. the whole network falls apart.  I plugged in a sniffer and I'm seeing all kinds of IP address conflicts among other things.  It turns out the router does not persist the IP addresses it previously assigned and after reboot all my smart plugs, echo dots, etc. are all stomping all over each other.  This is really unbelieveable.  I've never seen anything like this.  The network just goes to pot, ARP (address resolution protocol) goes nuts, and it takes awhile for all the addressing to resolve itself.
Another concerning issue is that the Satellite keeps sending out ARP requests from 192.168.1.250.  This must be some preconfigured IP address which doesn't even match the configured network of 192.168.0.0/24.  I changed the default network to match my previous network to match some static devices.  The Orbi Satellite does show an address like 192.168.0.27 in addition to the bogus one, but it is random on boot and often stomps on other devices.  I'm not surprised so many people have problems with what I've seen so far on the sniffer.  I'm getting close to ripping it all out or else putting in my own DHCP server.  I do this stuff for a living, it's not how I want to spend my freetime.
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 11
ekhalil
Master
Re: DHCP leases not persistant after restart
@NetworkEng wrote:
Another concerning issue is that the Satellite keeps sending out ARP requests from 192.168.1.250.  This must be some preconfigured IP address which doesn't even match the configured network of 192.168.0.0/24.  .........
This IP address must be coming from another router in your network. Are you sure that the ISP modem (the internet box) is bridged and is not acting as another DHCP server in the network?
Message 2 of 11
NetworkEng
There are no other routers in the network.  The cable modem is a Netgear CM1100.  The IP 192.168.1.250 has the same MAC address as the other IP 192.168.0.27 that the Orbi Satellite is using.  It's just bad behavior, some static backup IP configured on the satellite.  It just sits there arping for all the IPs it used to know about before the restart of the Orbi router.  All the network clients ignore it since it's on the wrong network.  It just suggests to me the router/satellite combo doesn't fully reconfigure itself to the new network range.
I'm actually more concerned about the lack of DHCP lease persistance.  Every time I restart the router everything gets a new address (and yes it's the Orbi doing the DHCP).  Ironically I noticed it while reserving static IP addresses to avoid things like printers changing IP addresses.  I recall folks were having a problem with a particular doorbell and the solution was to give it a static IP.  DHCP servers need to remember the addresses they have already assigned when they restart or else there is chaos.
Message 3 of 11
ekhalil
Master
@NetworkEng wrote:
.......  Ironically I noticed it while reserving static IP addresses to avoid things like printers changing IP addresses.  .......
How do you do "reserve static IP addresses"?
Message 4 of 11
ekhalil
Master
@NetworkEng wrote:
........ The IP 192.168.1.250 has the same MAC address as the other IP 192.168.0.27 that the Orbi Satellite is using. .......
I think I saw this IP address assigned at first to my satellite. It seems it's a default "temporary" IP address for the satellite when it has no connection to the router. Once the satellite finds the router it will get assigned the correct IP address by the router.
Message 5 of 11
st_shaw
Master
The satellites do have 192.168.1.250 hardcoded as a backup address. This is used if the satellite is not configured, but I'm not sure whether this is used at every boot-up or only when the satellite has been reset and has no prior configuration.
I'm not sure about the DHCP issues you are having.  I run my Orbi in AP mode with another router so I don't see anything like this.  What you describe doesn't make sense though.  Devices receive addresses via DHCP and will hold onto the addresses until the lease expires.  Clients don't know the Orbi rebooted and restarting Orbi doesn't cause your devices to request new addresses.
Something else must be going on.  Hard coding IPs into devices could cause problems, if the hard coded addresses were within the DHCP range of Orbi.
Message 6 of 11
NetworkEng
I agree it's likely a temporary IP so the the Orbi router can configure the satellite.  I was just surprised to see that it was also sending out arp requests because it's on the wrong network once the network gets changed so it's broken in that regard.  It doesn't seem to cause any problems, unlike the DHCP issue.  I'm a little surprised on that one because most developers leverage linux source and dhcpd is one of the best and certainly maintains a lease file for use on restart.
FYI, static reservations are under Advanced->Setup->LAN Setup.  You can either select an existing DHCP reservation and turn it into a static reservation (client still uses DHCP but always gets the same address) or you can add a new MAC address entry for a device that has a static IP manually configured.  The second case prevents a duplicate DHCP assignment of that same address if it's within DHCP scope range.  A good DHCP server should always check to see if addresses are in use before assigning them.  That doesn't seem to happen either.
Message 7 of 11
ekhalil
Master
@st_shaw wrote:
.......  Hard coding IPs into devices could cause problems, if the hard coded addresses were within the DHCP range of Orbi.....
@NetworkEng If you set static IP addresses in the devices then please make sure these addresses are outside the Orbi's DHCP range, but within the LAN segment (the set netmask in Orbi)
Message 8 of 11
st_shaw
Master
Sounds like the satellite is having trouble getting its configuration from the router.
Sounds like something in your network configuration might be causing issues.
You mentioned the network was MoCA and had access points.  Are you running wired backhaul over MoCA with Orbi?  If so, revert to wireless backhaul and see if that resolves your issues.
Message 9 of 11
NetworkEng
Yes, my DHCP ends at .199 and static assignments are above that.
Devices do receive addresses from DHCP and typically renew at 50% of lease time.  Clients DON'T know the Orbi rebooted and so they keep using their address.  Meanwhile the Orbi starts handing out these already in use addresses to new clients.  This is the problem I'm trying to get to and hoping somebody from Netgear sees it because it's got to be impacting lots of people.  I bet this is one of the reasons many people seem to be loading old firmware.  Most devices seem to detect the IP conflict and re-initiate DHCP so the problem resolves fairly quickly but a few devices will hold their address for a long time and so conficts can persist.
Anybody running in Router mode is free to try this.  Look at the addresses assigned under attached devices, then do something to restart the router.  Go back and see if devices still have the same addresses.  I bet not.
Message 10 of 11
NetworkEng
I replaced all the MoCA access points and router/modem (from a major cable industry leader that I used to work for and do backend engineering support for).  The current network is as simple as it gets.  Its the CM1100->Orbi->Orbi Satellite.  The backhaul is wireless.  The satellite does probably use the hardcoded 192.168.1.250 while the router reboots.  It actually uses both for awhile.  I sort of regret mentioning that issue because it is probably temporary and doesn't really matter.  Its just extra arp noise.  All I really care about is the DHCP server needs to remember the addresses it has assigned after it restarts.  I assume this happens to lots of other people but they don't notice or they don't realize why the network falls apart periodically.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 5396 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
