Orbi WiFi 7 RBE973
Reply
Echo multi room doesn’t work when one echo is on the router and one is one the satalite.
Dorkapotomus
Follower
Title has the details. Same WiFi network but since one is on the router and one is on the satalite they believe they are on different networks. Any ideas? Is this just a flaw with the echo?
Message 1 of 3
Guru
Re: Echo multi room doesn’t work when one echo is on the router and one is one the satalite.
What model orbi system do you have?
What FW is loaded on the orbi system?
Is the Echo devices working?
Message 2 of 3
angr
Star
This works fine for me.
Three Echo's, two of them connected to different sat's, and the third connected to the router.
What error are you getting?  Can you use other functions such as 'Drop In' from one to the other etc.?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 711 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
