× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Images in email web
Mikeal1st
Follower
Images in email web
Certain images in email and the web sites linked to them don't load, but if I use my cable router they come through fine. This appeared to start happening two weeks ago for some unknown reason.  I also have some devices in the house that are showing an error in the connection to Or I but I'm not sure what they mean.  I have since restarted all networks in my house and reset the Orbi system to factory setting but the problem continues. I have an Orbi RBR 50 with one satellite connected by Ethernet.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
CrimpOn
Guru
Re: Images in email web
Could you please explain:
  • Which firmware release is running on this Orbi?
    (Shown in the upper right part of the Orbi web interface.)
  • Is Disney Circle and/or Bitdefender Armor activated on this Orbi?
Thanks
Message 2 of 3
Guru
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? IF so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 516 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
