- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is an upgrade in order
- Mark as New
- Bookmark
- Subscribe
- Permalink
I currently have the ORBI AC3000 (RBK53) and it has been in operation for the past 3 years. I wonder if it would make sense to upgrade to something like the ORBI AX5400 (RBK763)? I just recently reconfigured the RBK53 from all AP (Access Points) to a router and the two satellites. My Cisco router and firewall was quite old and I could not get any updates as it is no longer available, hence, the redoing the ORBI configuration. I have about 35 devices on the network and the RBK763 provides greater square footage coverage. Any thoughts
Don
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is an upgrade in order
WiFi coverage is more marketing hype than reality. If the entire house has adequate WiFi signal, then upgrading is not likely to make much difference.
The original Orbi product line, including the RBK53 package ("K" stands for "Kit", consisting of one RBR50 ("R" for router) and two RBS50 ("S" for satellite), was introduced in 2016 and is based on radio chips supporting WiFi5 (the 802.11ac WiFi standard formalized in 2008 and amended several times: https://en.wikipedia.org/wiki/IEEE_802.11ac-2013 )
The Product Data Sheet claims it can provision "up to 6,000 sq. ft.". In actual practice, WiFi coverage is a function of where it is practical to locate the three units, the shape of the building, and building construction.
The RBK753 (again a "Kit") supports WiFi6 (the 802.11ax standard first approved in 2014 and amended as recently as 2021: https://en.wikipedia.org/wiki/Wi-Fi_6
Both the RBK53 and RBK753 are equipped with gigabit Ethernet (WAN and LAN) ports, so neither is suitable for the emerging "greater than gigabit" ISP speeds that are now on the market (2.5G mainly).
The key difference is the increased efficiency of ax over ac when communicating with devices that support ax. As of this summer, my home now has 4 devices (out of 50) that support ax. All those thermostats, security cameras, smart plugs, doorbells, etc. etc. have the original radio chips they came with. So, switching from an ac based system to an ax based system might enhance the speed of those four devices. Would the user notice any difference? I rather doubt it. A Facetime or Zoom call requires a certain amount of bandwidth. Having surplus bandwidth cannot make much difference.
Because the WiFi 'backhaul' connection between router and satellites has been changed from 802.11ac to 802.11ax, then the backhaul link will be faster and more efficient. Customers who have upgraded to very fast internet may indeed notice things connected to satellites are more 'snappy'.
These AX based products do not support the (even newer) WiFi6E (6GHz frequency) WiFi. Nor do they support whatever the hell WiFi7 is going to be when it gets delivered this year (next year?) Once again, I have zero devices that support WiFi6E, so installing a WiFi network that supports it does me no good.
Notice that as of March, 2023 there are zero iPhones that support WiFi6E:
https://www.techietech.tech/wifi-6e-compatible-smartphones/
My take? If you are
- loading up on WiFi6 capable devices
- are not satisfied with the performance of the current network (coverage or speed)
- are eager to "move up" to a gigabit connection from the ISP and want "blazing fast" performance from those WiFi6 devices
Then I might start looking around at "what to buy next". Everybody makes WiFi6 (and 6E) WiFi systems at all price points and with varying features..
