- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue with Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are connecting your Orbi router and satellite together via ethernet, there is no need to have the radio backhaul channel active, yet there is no way to turn this off in the software.
In my case the channel is impacting on my AV senders I use within the house.
It would be nice is Netgear upgraded the software to enable the deactivation of the radio link when not needed and hence reduce the 5GHz radio polution within the house.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issue with Orbi RBR50
Probably "preaching to the choir" in this forum. Netgear has a forum where people make suggestions:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Disable Daisy Chain to stop the backhaul channels in the Satellites.
- Telnet to Orbi Router and do the following commands to stop the backhault channel in the Router:
- config set endis_wla_2nd_radio=0
- config get wl5g_BACKHAUL_AP
- ifconfig $(config get wl5g_BACKHAUL_AP) down
- config commit
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried to use Putty to telnet into the RBR, but it's failing. Is there anything special I need to do to enable Putty to connect? I have left the setting as default.
Thanks
Robert
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, There looks like other s in that forum that have suggested similar things.
Robert
- Mark as New
- Bookmark
- Subscribe
- Permalink
Telnet is turned on using the Orbi "debug" page. i.e. 192.168.1.1/debug.htm. Any telnet client will then work. I, personally, use Putty because Putty makes it easy to save a complete log of the session.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't see the debug page in the GUI.
I'm in AP mode rather than router mode. Does that make a difference ?
Robert
- Mark as New
- Bookmark
- Subscribe
- Permalink
No.
I am also in AP mode and can connect to debug.htm.
Can you connect to the usual GUI page? Try doing that and then move on to debug.htm.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry Guys,
I can log into the GUI but I don't see the debug page or option anywhere, and hence can't turn on Telnet.
I've been throught the user manual too.
Was this option taken away wihen the latest firmware was released ?
Am I missing something ?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ekhalil wrote:
It’s not in the “regular” GUI. It’s an additional Debug GUI that you can reach on orbilogin.com/debug.htm or 192.168.1.1/debug.htm
What @ekhalil says is "literally correct." i.e. once the browser is connected to the Orbi web interface (either as orbilogin.com or using the IP address, which is often 192.168.1.1) then replace the letters "index.htm" with "debug.htm" and press <Enter>. There is NOTHING on the regular Orbi interface that can be used to access "debug" mode. What we are doing by using Telnet to access the Orbi internals is not what Netgear expects customers to do. It is not entirely clear why Netgear allows terminal access to the Orbi line, but we are very happy that they do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah, now it makes sense.
Just did it.
Should I expect a response back from the commands ?
Now to test to see if this has actually worked.
Thanks guys, appreciate the help from everone who has had some input in helping me.
Now , what else can I do using the Telnet command ?
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you want to do?
@ekhalil guided me through the process of using telnet to "unblock" the drop down for the wireless region in a couple of Orbi devices. As delivered, devices sold in the USA seem to be locked to the local wifi bands. They will not adapt automatically to the local region. Changing this is a simple telnet trick, but not one that most people need to worry about.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I logged onto the router, then entered debug, And I just get a spinning dial. It wont display the debug GUI. Any suggestions? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just tried Chrome, Firefox, and Opera. Entering "192.168.1.1" (no quotes. this is the IP of my Orbi router) All three first popped up a box requesting user name and password. i.e. "admin" and my "secret admi password." For a few seconds, there was a spinning dial, and then the page appeared. I then replaced "index.htm" with "debug.htm", got a spinning dial for a few seconds, and then the web page.
Do you get the regular web interface?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used Firefox. I’ve tried 2 different ways, multiple times. I can log on successfully with my userid and password by using the urls:
Https://orbilonin.com/ And
Https://orbilogin.com/debug.htm
If I first login through https://orbilogin.com/index.htm, I can change the ‘index.htm’ with ‘debug.htm’ but still just get a spinning wheel.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try 192.168.1.1\debug.htm instead. I don't think the orbilogin.com works for debug.htm
@JABuntyn wrote:
Thanks for the comments.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank everyone for the comments and questions. Great user community.
I have tried using the IP address as well.
192.168.1.1/index.htm or orbilogin.com/index.htm both go to the same place.
Once logged on and the standard interface comes up I can manage the router from here just fine. If I replace the 'index.htm' with 'debug.htm', I get the spinning wheel.
I've also tried 192.168.1.1/debug.htm and orbilogin.com/debug.htm. Through both, I am prompted for the userid and password. Then I get the spinning wheel. I have to close the browser window because there is no recovery.
I'm using Firefox browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try IE11 or Opera with 192.168.1.1/debug.htm.
I would try a factory reset on the RBR and setup from scratch, don't load any saved backup configs from file, then try 192.168.1.1/debug.htm again.
