Orbi WiFi 7 RBE973
Reply
Issues with MSFS2020
astrojohn
Tutor
I've narrowed down some connection problems (failure to get past initial screens) with MSFS2020 to my Orbi RBR40 router.  If I disconnect the router from the Spectrum modem and connect my flight sim PC directly to the modem, all is well.  Going back to the default config: modem->RBR40->all connected devices including the sim PC, the sim PC will fail to execute properly (1 of 5 simulator executions actually works).  If I reboot the router, it will work for a while, then crap out!  I also get a ton of DoS tetxts in the Orbi log...
I've tried numerous settings including setting up a DMZ and disabling DoS protection - nothing made a difference.  Getting ready to junk it and go to another vendor.
Any ideas?  Yes, the firmware is up-to-date.
John
Message 1 of 3
CrimpOn
Guru
Re: Issues with MSFS2020
Can you provide the model number of the Spectrum modem?
Is it a "modem only" or a combination modem/router/WiFi?
Message 2 of 3
astrojohn
Tutor
TM1602, modem only,  incl phone
Gets hundreds of DoS of various categories every day.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 442 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
