- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Missing Devices and Satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Missing Devices and Satellites (RBK43S)
The annotation (jpg) below is a sample off the garbage I am seeing. @Greg00001 do you have Broadlink devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What browser are you using? Does this happen in other browsers? Try IE11, Edge, Firefox or opera?
Be sure to clear out all browser caches before entering the RBRs web page.
This only happens when you use these blaster devices?
@arnb wrote:The annotation (jpg) below is a sample off the garbage I am seeing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There was a known problem with v30 FW and the RBS showing disconnected on the RBRs web page. NG pulled v30 from public download. You should update to v16 and the RBS will appear correctly. I experienced the same thing when I had v30 loaded. v16 works fine.
@Greg00001 wrote:I've had the same issues as you. Satellites showing disconnected, wrong # of devices listed. Even after factory resets and starting from scratch after each firmware try I always revert to this firmware. It has been the most reliable and stable for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@arnb wrote:The annotation (jpg) below is a sample off the garbage I am seeing. @Greg00001 do you have Broadlink devices?
I do not have any Broadlink devices but I have had the display as garage in the past when some of my devices had duplicate IP addresses. I don't recall if it was as bad as yours. Even though the devices were rebooted/powered off they were sticking with the IP address they had after I did a factory reset of the Orbi. Don't ask me why but I had to wait a day or so until they did their own ip renewal. I have around 60-66 devices on my network at anytime.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It occurs in all browsers; firefox, chrome, edge, opera, and the Orbi app. For the record I use Vivaldi for my go to browser on Windows 10 and Android 9 phone.
Everything worked until I powered a Broadlink RM Mini3, IR blaster. Everything continues to work, including the IR devices, except for the the attached device page
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd update to v16, RBS first, then RBR lastly, Then factory reset and setup the RBR and RBS from scratch. Be sure to clear out all browser caches.
Start turning on devices and letting them connect. I would try using Edge or Firefox browsers for this.
Icons should appear correctly on the web page and not broken picture icons.
The try your IR devices and see if the web page appears incorrectly again. If so, this is something to address with NG support.
@arnb wrote:It occurs in all browsers; firefox, chrome, edge, opera, and the Orbi app. For the record I use Vivaldi for my go to browser on Windows 10 and Android 9 phone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the link for my RBK43S. Using the latest release makes it worse.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:There was a known problem with v30 FW and the RBS showing disconnected on the RBRs web page. NG pulled v30 from public download. You should update to v16 and the RBS will appear correctly. I experienced the same thing when I had v30 loaded. v16 works fine.
I have no issues with devices on 2.3.5.30 with devices disappearing but I do on later versions, even the 2.5.1.16 you mention.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did the factory reset and what not with the latest release on router and satellites a few weeks ago when Firefox was my go to browser. Today was my "last" attempt at this insanity.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to contact NG support and let them know what your seeing then. Not much else we can do here in the forums.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Updated Router firmware to V2.6.1.36, and Satellites to V2.6.1.38, corrects the Attached Devices issue. However, the BitDefender option is now missing from my RBK43S. Submitted ticket to support.
- « Previous
- 1
- 2
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
