Orbi WiFi 7 RBE973
Reply
Multiple SSIDs
awells464
Follower
Multiple SSIDs
Hey I just got this not realizing I can only do 1 SSID, I would not think that would be a limitation considering just about every other device out their is capable of this. Is there a way I can get multiple SSID's? I run about 4 to isolate different device types.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
Guru
Re: Multiple SSIDs
MESH systems are based on having 1 SSID and using Smart Connect to automatically connect devices to there best supported frequencies.
Message 2 of 3
st_shaw
Master
Re: Multiple SSIDs
@awells464 You can create separate SSIDs for the 2.4 and 5 GHz bands as shown in this thread:
https://community.netgear.com/t5/Orbi/How-to-set-a-separate-SSID-for-the-5-GHz-network-on-your-Orbi/...
However, note that creating separate SSIDs does not isolate devices from each other. To do that you would need a router that supports SSIDS tied to separate VLANs, and none of the NETGEAR home routers support that.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2667 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
