- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My Orbi RBR10 is slowing down my internet connection from 50 MBPS to 10 MBPS
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBR10 - Orbi Dual-band AC1200 Mesh with three satellites. The main orbi is plugged with a netwrok cable to my internet's provider modem-router-my internet plan is 50 MBPS- but the wifi signal sent by the orbi is only 10 MBPS. I tried connecting another router, a Netgear Nighthawk AC1900, directly to my internet's provider modem-router and the speed is back to 50 MBPS which means somehow the Orbi system is dropping the speed from 50 to 10.
Any help would be greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My Orbi RBR10 is slowing down my internet connection from 50 MBPS to 10 MBPS
When you're testing, are you testing hardwired into the rbr10 or wireless?
and if you're testing wireless, are you connected to the 2.4ghz or the 5ghz?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am testing it wireless. When testing the Orbi I am connected to 2.4 GHZ since there are no other choices and I am using a Samsung Galaxy Note 10 plus, the speed is about 10 MBPS. When I test the wifi signal with the router NightHawk my phone connects to a 5Ghz signal and the speed is 50 MPS. In both cases both devices,the Orbi and the Nighthawk are hardwired to my internet's provider modem-router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@hugopaul wrote:I am testing it wireless. When testing the Orbi I am connected to 2.4 GHZ since there are no other choices and I am using a Samsung Galaxy Note 10 plus, the speed is about 10 MBPS. When I test the wifi signal with the router NightHawk my phone connects to a 5Ghz signal and the speed is 50 MPS. In both cases both devices,the Orbi and the Nighthawk are hardwired to my internet's provider modem-router.
Why is there no other choice than 2.4Ghz?
Who is your ISP and what equipment did they provide?
What is the current firmware on your Orbi device?
What device model is your Orbi router connected to?
Have you changed the network cable connected from the ISP device to your Orbi router?
Try these settings:
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Set Short preamble mode. Save settings, reboot Orbi.
