Orbi WiFi 7 RBE973
Reply
Need help with wired backhaul on RBR50 and two RBS
Pujones1
Follower
Can someone give me some step by step instructions on how to enable wired backhaul on RBR50 and two RBS50? My setup up is Netgear CM1150V->RBR50 on the second floor->Netgear 16port unmanaged switch next to the router->two RBS50 on the first floor. ON THE ORBI APP: One sat shows hardwired and the other shows wireless but both are showing magenta.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
ekhalil
Master
Re: Need help with wired backhaul on RBR50 and two RBS
If you have Orbi software 2.3.5.30 then please follow the steps in this post: https://community.netgear.com/t5/Orbi/Wired-Backhaul-in-recent-firmware-releases/m-p/1783871#M67538
Message 2 of 3
Guru
What is the model# of the ethernet switch in the configuration.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 508 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
