- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - Orbi 20/30/40 and 50 series Firmware Version 2.7.5.6 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bug Fixes: 02/07/2025
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Download Link:
Orbi 20 Series:
https://www.netgear.com/support/product/rbk20/
Orbi 30 Series:
https://www.netgear.com/support/product/rbk30/
Orbi 40 Series:
https://www.netgear.com/support/product/rbk40/
Orbi 50 Series:
https://www.netgear.com/support/product/rbk50
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual.
To find your user manual, visit https://www.netgear.com/support/
Then enter your model number in the search box, and click the Documentation button on the product page.
NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
If you manually update, be sure to update the RBS first, then RBR lastly.
NOTE: Update the RBS first, then the RBR lastly. After the FW files are loaded and the RBS and RBR are ready, power OFF the RBS and RBR for 2 minutes then back ON.
Unplug the power adapters from the power wall outlet.
A factory reset maybe needed if problems are encountered:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200. Not required.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
This article applies to all Series:
Let us know how it works for you in this thread please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RBR50 / RBS50 Firmware Version 2.7.5.4
Powered then all off for 45 seconds or so and restarted. Done.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - Orbi 20/30/40 and 50 series Firmware Version 2.7.5.6 Released
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
