Orbi WiFi 7 RBE973
Reply
No lights
4thefamily
Tutor
No lights
Power on, but no Internet and no lights...The WiFi on our Orbi is no longer recognized. Tried to reset, but Orbi is not responding. No top lights. Able to connect to cable WiFi so there is Internet coming from from the Modem, but cannot get the Orbi to work.
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 8
Guru
Re: No lights
Try a different power supply? Try one from the RBS to see if any LEDs turn on.
Message 2 of 8
4thefamily
Tutor
Re: No lights
Green LED lights up, but nothing else is working. Won’t connect to Internet, won’t reset, no top lights are flashing like during set up.
Message 3 of 8
Guru
Re: No lights
I would make contact with NG support to see what options are available to you.
Good Luck.
Message 4 of 8
vajim
Master
Re: No lights
Is it new?
Message 5 of 8
4thefamily
Tutor
Re: No lights
We have had it five months. I contacted support and after speaking with someone who didn’t seem to know much about the device, they are sending a replacement since it is still under warranty. I was trying to see if I was missing something before going that route.
Message 6 of 8
vajim
Master
Re: No lights
Nice
Message 7 of 8
Guru
Re: No lights
Good to hear it's under warranty and they are replacing it. Good option. Let us know how the new one works out for you.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 982 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
