- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
No upload on sattelite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No upload on sattelite
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can see that you have Daisy Chain enabled. Please disable it before doing the procedure above. You don't need Daisy Chain as you only have one satellite.
If you see in the snapshot that you posted below:
The red boxes are around your backhaul networks: One from your Router and the other one is from your Satellite. Not sure which is which (Please deactivate Daisy Chain so you only keep the Router's network).
But you can see that where you are standing with your phone one of the networks has very low level (-87 dBm) so I don't think that you have a good coverage there on that channel.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the second screen shot was when you were standing close to the router then the MAC ending with 8f:ca is the Satellite and 6f:27 is the Router.
Please deactivate Daisy Chain, you don't need it, the network from the Satellite just imposes interference on the network from the Router since both transmit on the same channel.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So for you to have good speeds from devices connected to the satellite, you should get good level of signal for the Router network (MAC ending with 6f:27) when you stand with your wifi analyser close to the Satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Geniet wrote:
Yes , I think you are right. Thanks all of you for all your support , it has been very helpful even though it did not work. I have learned a lot about my WiFi that I never knew before. I will remember to post it here when I get a new one that is working ...
Yes please keep us updated how it goes.
Good luck!
- « Previous
- 1
- 2
- Next »
