Orbi WiFi 7 RBE973
Reply
ORBI Limiting Internet speed to 100mbs
ppilot212
Star
So recently Comcast Increaed the internet speed in our bundle to 150mbs, but I noticed after a couple weeks that I was still only getting 100mbs
- Called Comcast and through their troubleshooting process, confirmed that I could get the 150mbs if I connected my PC directly to the Cable Modem
- Went through and checked all the cables to the modem, router and Gigabit switch, to verify everything was at least Cat 5e
- Ran speed test with the main PC (which connected directly to the router va ethernet) and my phone Pixel 2....both of the results were almost identicle.
- LAN speeds are just fine as file transfers typically max out around Gigabit levels.
At this point, I don't know what to do besides Factory Resetting the entire system again (which I have done since they increased my speed and had no effect)
Thoughts?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Guru
Re: ORBI Limiting Internet speed to 100mbs
What is the Mfr and model # of the ISP modem?
Is any QoS or Speed test enabled on the router?
Testing with different browsers like IE11, FF or Opera?
Thoughts?
Message 2 of 4
ppilot212
Star
Motorola SB6141
Under the QoS tab the only thing that pops up is a speed test.  Is that something that can be disabled? Just to add another layer to the wierdness that if I run the speedtest there I get the full speed.
Edge and Firefox were slightly faster, still not faster than 100mbs.
UPDATE: Reset my all my network hardware and I get the full speed now.  Not sure what was going on but we are good to go.  Thanks for the post!
Message 3 of 4
Guru
Reset network HW as in? Did you reset the router?
Motorola SB6141
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1906 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
