- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI R50 Wifi link speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wifi issue with new Orbi R50, When using virgin media superhub 3 i get expected link speed 450mb on wifi, however on the Orbi this drops to 300mb. Mobile phones other devices connect and get full speeds. any advice on resolving this would be greatly appreaciated
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI R50 Wifi link speed
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the response.
The virgin media super hub 3 is set to modem mode and it looks like the orbi is setup in router mode. Would my best option be to set up the Orbi as an AP Instead
- Mark as New
- Bookmark
- Subscribe
- Permalink
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Might try mode in router mode and Orbi in AP mode as last resort configuration to try
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for all the suggestions and advice and i have tried everything you advised.
1 - currently have modem mode on the sh3
2 - Router mode on Orbi 50
3 - Mobile devices etc all connecting a good speeds
4 - Imac and macbook pro when connected to the sh3 as standard config get correct link rate, however as soon as these are connected to the orbi i only get link speed of 300mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow, i have just come off support with Netgear over an hour long and still no closer, they are now saying that i need to contact apple to change settings on laptop ?
I just do not understand where there is a difference
https://prnt.sc/q4t9n3 - ORBI 50
https://prnt.sc/q4ta6e - SH3
I have changed channels and done all the recomended setttings the laptop clearly supports the speed under the SH3 so what is stopping it reaching this and all other devices are ?
hope someone can help
regards
john
- Mark as New
- Bookmark
- Subscribe
- Permalink
What year are the iMac and Mac Book Pro?
What OSX version is installed on the iMac and Mac Book Pro. I have a Mac Book Pro 2018 and haven't seen this. Use both 10.14 and 10.15. Orbi loaded with v40.
Beamforming and WMM enabled?
20/40Mhz co-existance unchecked and set for 40Mhz?
@Johnhorton1979 wrote:Thanks for all the suggestions and advice and i have tried everything you advised.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Macbook Pro Mid 2012 Retina 15" running 10.15.1
IMac 2015 5k 10.15.1
Seems that since connecting the orbi the internet on these 2 devices has slowed down
I dont understand why whe connected to the SH3 it everything was ok
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll check my MBP 2018 that dual boots with 10.14 and 10.15. I have a Mac Mini 2012 that I know max's out at 450Mbps on 5Ghz. I'll check that as well.
I have heard people say 10.15 introduces new and different behaviors. Possible some incompatibilities between OSX and hardware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
great thanks, i have another older macbook on high seirra and that does connect at 450mbps. and 10.15.1 has been perfect under the SH3 setup 450mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the older Mac High Sierra connects at 450Mbps with the Orbi? If so, sounds like this maybe a 10.15 issue possibly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok we can skip that.
The 10.14 macbook i tried was in my garden office, which is the connected to the house via cat6e and i have a seperate TP Link EAP WIFI which the macbook was connected too. The cat6e is run from the back of the orbi 50 ethernet port down to the garden office.
Macbook connected in garden office i got 450mbps Link Speed on MAC OS 10.14 TP Link EAP WIFI
Macbook connected in house i got 300mbps Link Speed on MAC OS 10.14 ORB50
Macbook connected in garden office i got 450mbps Link Speed on MAC OS 10.15.1 TP Link EAP WIFI
Macbook connected in house i got 300mbps Link Speed on MAC OS 10.51.1 ORB50
To say im confused is an understatment im guessing there is something on the ORB50 causing the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW version are you using on the RBR currently?
Has a factory reset been performed and walk thru the setup wizard and complete it. Then connect on of the Macs to the Orbi RBR and see the connection rate? I would turn OFF the RBS temporarily while you try this as this doesnt' need to be reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware V2.5.0.40
I have hard reset several times and run through everything again and again very frustrating even spoke to netgear support who are of no help. I think im pretty close to sending it back as was expecting better even though its really improved wifi around the house, just dont get why if affecting these devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
So heres what I found with my MBP2018, It's seeing at least 520Mbps. however I noticed the speed drop to about 350Mbps while just stting there. I then kicked off a speedtest with Ooklas speed test app and watch as the test ran that the wifi rate went bsck up to 520Mpbs. I was about 4 feet away from the RBR line of sight. All this was in 10.14. I saw 866Mpbs when I booted to 10.15 on the MBP and same drop off behavior. So I think the wifi drivers on the MBP are probably slowing the rate if nothing is flowing thru the connection. Are you having any data flow thru the connection when your looking at the connection rate? Or is the 300Mbps seen all the time regardless of data flow or not? Try this to be sure.
My Mac Mini 2012 barely go anything up to 270Mbps. However is farther away from the RBR and not in line of site. Not sure how good the radios on the Mini are though I had seen 450Mbps before with it. It mostly wired to the network anyways.
v40 here as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the macbook in the same room the connection stays at 300mbps regardless if data is running through.
I have just tested my Imac in the office garden this starts at 1300mbps and drops to 879mbps.
When running speed tests on the imac in the garden results are not great 150mbs was previously hitting the full speeds with the SH3
Wasnt expecting such a drop to be honest been a nightmare. really cant think of anything else to do as everything worked fine under under the sh3 and if i unplu everything and go back to old set up everything works something on the orbi is causing this imo
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would presume that your Orbi maybe faulty. Since you've tired other FW versions, leads me to think this system is just bad and needs replaced or go with something else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Theres been others who have had faulty units out of the box. Getting another has resolved this.
Good Luck in your endeavors.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Right, so new unit has arrived all set up and everything is the same, so my guess is its not actually the orbi system thats the problem, All other devices work perfectly LAN connections are what they should be i think its something to do with the macbook & orbi just wish i could figure it out. but i feel i can rule out an actual issue witht he Orbi i think i need to investigate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Thanks for letting us know. Ya seems like if this is happing across two different systems, something is going on with your Macs. I would make contact with Apple support and point them to this thread for there review.
Possible there is a HW fault in the Macs. I would be interestest to know what they say.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it really is a strange one to be honest, although when the SH3 is connected in normal mode the tx rate fluctuates up to 450mbps i still do not get the full speeds and maybe never have just not noticed it. More investigation ahead i feel and will contact apple.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
bit of an update, tried ethernet into the imac and also a pc run speeds tests on them both and the Imac get around 270mb and the pc is getting around 370mb. Im really confused as it was is going on
