× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
ORBI RBS50Y-EXT not showing in the network map
voyseygw
Follower
My External RBS50Y does not show up in network map. Tried to reboot it, it goes through all the motions of reboot I get a steady blue light then it goes out, then nothing! Still not showing. What should I try next?
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 3
Guru
Re: ORBI RBS50Y-EXT not showing in the network map
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
Message 2 of 3
CrimpOn
Guru
My first step would be to look at the Orbi router Attached Devices display on the Orbi web interface (http://orbilogin.net)
If the RBS50Y is in Extender Mode, it will appear as a regular device, not as a satellite.
and check out the RBS50Y User Manual:
https://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_UM_EN.pdf
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 596 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
