× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
ORBI WIFI NETWORK NAME
YONGSTAN
Hi all,
I am running on 2GB dual broadband at home, split into two 1GB bandwidth, on RBR50 + Satellite and RBR40+Satellite respectively. Both are currently on different wifi network name. Wanted to know if it would be possible to use the same wifi network name for both networks?
Message 1 of 11
Accepted Solutions
Guru
Re: ORBI WIFI NETWORK NAME
The satellites can mix and match. Only thing to keep in mind is the backhaul for the lower models is only 2x2 and not 4x4 like the rbs50's.
so if you're daisy chaining them, put the lower backhaul device at the end of the chain to limit bottlenecks.
Message 10 of 11
All Replies
Guru
theoretically yes. You can.
In usage, you'd have all kinds of issues. You'd have devices on different networks or issues with joining the wrong network ie wrong IP addresses, wifi interference.
You'd lose the benefits to using orbi with the seamless wifi goals of orbi.
Is there a reason you want to go this route? Most wireless devices can't get close to maxing out a gigabit connection much less 2 gig.
The Orbi doesn't support link aggregation but you could get a router that does and place the orbi in wireless ap mode for wireless service.
I guess the question again is, what are your over all goals here?  Best way to implement seamless wireless integration, blistering hardwired speeds, etc.  the more we know the better we can help.
Message 2 of 11
Guru
oh and with your dual hookup, I assumed both had their own IP addresses? Just checking as Orbi has issues with 2 orbi routers on the same network.
Message 3 of 11
YONGSTAN
Yes. They have their own IP. Looks like its a no go...
Message 4 of 11
Guru
Not necessarily saying its fully no go. You could put all your wired devices on one of the 1gig services so that the other was reserved just for wifi devices. And you can leave the orbi's with separate wifi's.  Just make sure to separate out the channels far enough to limit interference if possible. Lots of possiblities for setup and better to have the option than those of us without.
Again, not sure of what the overall intention is to help you figure out a good solution. the seperate IP addresses is a benefit for some (IoT devices, servers, etc) to reduce congestion on one network or for network security. Its a downfall for others as they like all their IP address's in a set range.
  Up to you how you prefer managing your network.
Message 5 of 11
YONGSTAN
4 storey linear house with narrow width and deep plan. Currently the RBR50+satellite can only cover the front section, while the RBR40+satellite the back section. My original intention was to have RBR40+satellite serving all the stationary devices such as TVs, TV setup boxes, robovacuum, Xbox, google home, Arlo etc. While RBR50 + satellite to cover the house for mobile devices.
Message 6 of 11
schumaku
Guru
A router with multi-WAN capability and enough bandwidth can deal with more than one Internet connection - you won't find these in the consumer market. And then, the 1 GbE Orbi wont be able to take a real advantage out of it.
Message 7 of 11
YONGSTAN
Ok. Thank you all for the prompt response!
Message 8 of 11
YONGSTAN
One last thing...
Can different models of satellites be used? Ie. for RBR50+satellite, can i connect my RBR40 satellite to the RBR50 as the 2nd satellite? Or must the same model be used inorder to work?
Message 9 of 11
Guru
Message 10 of 11
YONGSTAN
Thanks!!!
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 4276 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
