× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi AC3000 - Slow wifi, and is getting worse
mrmattis
Initiate
Hello
I have the following system.
Modem - Bridge.
RBR50 - Routermode - Auto Channel - Last firmware.
RBS - Last firmaware.
Backhaul - Wifi - Good connection.
When connecting with cable i get 500/500 from modem and satelitt, and this is what I pay for.
The first day when i connected the system I got about 400/400 on wifi, short distance from the router.
The next day average is about 200/200 short distance from router or satelitt.
I have tried factory reset, and nothing helps.
Beamforming is activated, and the rest is default.
My Aimesh had better performance on wifi, but it was unstable.
Where has my wifi speed gone? Cable speed is 100% up/down, and the system i stable, but slow on wifi.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 6
Accepted Solutions
Guru
Re: Orbi AC3000 - Slow wifi, and is getting worse
Thanks for posting back. Glad that you have some beta FW for your RBR50. Sounds like its working better for you. Keep us posted. Hope the new beta comes to the community soon.
Mark your post as resolved so others will now.
@mrmattis wrote:
I have installed beta firmware, 2.2.2.20. Seems to be ok now. Last resultat was 478/437 using Samsung S9+ wifi. 2 meters from router. Using cable is full speed, 500/500.
Message 6 of 6
All Replies
Guru
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What devices do you have connected to the system, wireless and wired.
What devices are you using to speedtest wireless with?
Wired speed tests working to spec?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? Should be WPA2 and AES only.
Enable MIMO and check speeds.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 6
Guru
Any progress on this?
@mrmattis wrote:
Hello
Modem - Bridge.
Message 3 of 6
mrmattis
Initiate
Message 4 of 6
ekhalil
Master
2.2.2.20? This is an Orbi Pro software, do you have an Orbi Pro?
I don't think there is yet a beta software for Orbi called 2.2.2.20.
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 18660 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
