× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Orbi CBR40 no modem lights and will not connect to internet.
Simcheck
Today my Orbi WiFi modem will not connect to the internet. I have a pink light on top, but absolutely no modem status lights on the front. When power cycling the modem status lights never blink at all. I have tried power cycling, disconnecting and reconnecting all cables, multiple factory resets, and I reached out to my ISP to confirm it’s not on their side. I called Netgear support, and they said it’s not a hardware failure, but I’m not convinced. Any help would be appreciated.
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 5
Accepted Solutions
Simcheck
Re: Orbi CBR40 no modem lights and will not connect to internet.
The device ended up having a hardware failure and after reaching back out to support I was able to get a tech to send a replacement unit. I received it today, and it is working as expected.
Message 4 of 5
All Replies
Guru
The front down link LED should blink with out ISP coax disabled when turned on. If it doesn't, the there is a problem on the CBR.
Can try a different power adapter and see though I doubt this would be a problem. Something NG should look into more.
@vkdelta
Message 2 of 5
Blanca_O
NETGEAR Employee Retired
Hi @Simcheck
I have sent you a message. Please check your inbox.
Blanca
Community Team
Message 3 of 5
Simcheck
Message 4 of 5
Guru
Enjoy. Smiley Wink
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2394 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
