- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Mesh RBR 20 - Problem PS4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ich habe den RBR mit einem Satelliten installiert. Ich habe das Problem, dass ich, aktuell bei einem PS4 Spiel Probleme mit der Netzwerk-Vebindung habe. Jedoch wenn ich am Satelliten ein Netzwerkkabel anstecke, funktioniert das Spiel ohne Problem. Über WLAN Verbindung zur PS4 baut das Spiel keine Verbindung zum Server des Spiels auf.
Über einen Hotspot (Handy) funktioniert auch alles.
Hoffe jemand hatte schon so ein ähnliches Problem und kann mir weiterhelfen.
Vielen Dank!
LG Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Mesh RBR 20 - Problem PS4
I have an issue with the WLAN of the Orbi.
The connection to the PlayStation is very well, but I don’t get access to the server of each game.
This issue came up several weeks ago.
If I connect the Orbi directly with the LAN then everything it’s working.
I restart the system several times.
The newest Firmware is installed.
The WLAN connection with the main router of the internet provider it’s working.
However, there is an issue with the WLAN of the Orbi.
I would be very happy about some helpful responses!!
Thanks!
Christian17
- Mark as New
- Bookmark
- Subscribe
- Permalink
So is the PS wired to the Orbi RBR when it works and if the PS is wireless, it doesn't work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The wireless connection is working, but I don’t get access to the online function of each game.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possbile that this could be a PS issue rather than Orbi if the wired portion of the PS works and wireless doesn't.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
If nothing here seems to help, I'd contact Sony for additional help and support regarding the wifi portion of the PS. There maybe a fault here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please give feedback to the question presented when you return.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi FURRYe38,
thank you for your helpful response.
I tried every proposals!!
In the end just one setting works:
The change from Router mode to Access Point mode.
Now everything is working.
Thank you agian for your help.
Christian17
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah must have a router upstream from the RBR. Glad AP mode works.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
