× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi Network Map
abel358
Orbi Network Map
I have an Orbi RBR20 with two satilites.  Typical the network map on my phone app shows the two satilites connected in parallel to the main router.  Recent the app shows the two satilites connected in series.  That is, one satilite connected to the router and the 2nd satilite connected to the first satilite.  What causes this and does it impact the performance of the system.  How can I get it to go back to the way it was?
Thank you for your help.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 7
Guru
Re: Orbi Network Map
Its called daisy chaining. In some instances it does degrade performance but I've only noticed speeds slowing down at maximum speeds and not for general usage.
you can disable daisy chaining through the settings for it.
But you might find that it provides better speeds this route if its defaulting to that setup.
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
Message 2 of 7
abel358
Thank you for your feedback.  I looked in my settings and do not see anywhere where I can disable daisy-chaining.  Can you provide additional details where to look?
Thank you.
Message 3 of 7
vajim
Master
Thank you.
https://kb.netgear.com/000048460/How-do-I-disable-daisy-chain-topology-on-my-Orbi-WiFi-System
Message 4 of 7
Guru
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Message 5 of 7
PatricOlsson
I want to avoid the star network setup?
Where are the settings?
Regards Patric
Message 6 of 7
Guru
Regards Patric
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 4528 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
