Orbi WiFi 7 RBE973
Reply
Orbi RBK 20: Network speed is getting slower after time
RainerB_Austr
Follower
Hi Netgear community,
for almost 2 months we have an Orbi RBK 20 system in Use with one sattelite. The problem I am facing is, that after some time (will monitor it now to get more detailed info on that) network speed is getting really slow. As soon as I reset the system it runs smooth again.
I did already set the 2.4 and 5 Ghz Wlan to custom bands. Furthermore i did turn of the Wlan from our LTE modem. I also did activate Mu-Mimo for testing and deactivated daisy chaining as well.
Does someone have some tips for me? Further settings i can change in order to keep the desired bandwith?
One more question: What das beamforging exactly do? Really hard to find info on that. As soon as I activate it i am not able to acces our Loxone server anymore (from the Iphone/Ipad at least).
Best regards (and sorry for grammar mistakes, I am not a native speaker) from Austria,
Rainer
Message 1 of 2
Guru
Re: Orbi RBK 20: Network speed is getting slower after time
Is the Orbi system operating in Router or AP mode?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
https://www.howtogeek.com/220774/htg-explains-what-is-beamforming-on-a-wireless-router/
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 599 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
