× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Orbi RBK20 won’t connect to samsung
Annoyed11111
Follower
We bought a new orbi RBK20 yesterday along with two Samsung Smart TVs. Now the orbi does appear to be pushing the wifi further in the house, though I’m now sure as far as it says on the packet but what I do know is that my other devices,phone, laptop, Apple TV etc can connect to Orbi but the new samsung smart tv can not. I’m not sure if the problem is the TV or the Orbi.
Message 1 of 2
Guru
Re: Orbi RBK20 won’t connect to samsung
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Do the TVs see the SSID from the Orbi? You can use the same SSID name and PW from the prior wifi routers configuration.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 734 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
