×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Orbi RBK40 as AP
Klysner
Orbi RBK40 as AP
Hi.
I have a RBK40 with a RBW30. But it's not enough for my house. I would like to buy a RBK20 with RBS20, because of the price, instead of buying two satellites. Then use the RBK20 as router, RBS20 and RBW30 as satellites for the RBK20. Then the RBK40 as a wired AP to the RBK20.
Is this possible?
If so, do I need two diffent SSID's?
BR, Kim.
Message 1 of 4
ekhalil
Master
Re: Orbi RBK40 as AP
@Klysner wrote:
Hi.
Is this possible?
BR, Kim.
I think that you meant RBR in all RBK that you mentioned above! 🙂
Yes, the configuration you are suggesting above should be ok:
RBR20 as your main router (in Router Mode) with two satellites: RBS20 and RBW30.
Then you want to use the RBR40 as a wired AP (in AP Mode). In this case, yes you have to use 2 different SSID's in the RBR20 and RBR40.
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 2 of 4
Klysner
Yes I saw this just now. Hoping for a firmware update, so the RBK40 can work as a satellite. Don't wan't two SSID's again. That's why I changed to the Orbi system.
Message 3 of 4
Guru
Any RBR## unit will never be supported as a satellite. Only works in main router mode or AP mode only. Will not work as a satellite or work as a extender for wifi.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 4
Discussion stats
  • 3 replies
  • 738 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
