Orbi WiFi 7 RBE973
Reply
Orbi RBR20 Losing device autorization
mumugalou
Hello,
I'm using the acces control for more than one year without any problem.
But recently, i have tried to add 2 new devices to the allowed list, it works for some time and then randomly, the 2 new device are set back to the blocked status without any reasons.
It is really boring, any idea of the rootcause ?
Thanks for your help.
Firmware V2.3.1.58
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
CrimpOn
Guru
Re: Orbi RBR20 Losing device autorization
Well, my theory about the "app" doesn't seem to be pertinent.  One thing I keep forgetting to do is click on the "Apply" button.  I do my business and go on to something else and then wonder why my change didn't take.   You are probably more careful.  So, "I got nothing".
People just hate doing a factory reset, but sometimes it is the only thing that works.
Message 5 of 5
All Replies
Guru
Was the FW recently updated when you started noticing this problem?
If so, you may need to perform a factory reset and setup from scratch and then re-configure Access controls.
Message 2 of 5
CrimpOn
Guru
Are you setting Access Control using the web interface or a smartphone app?
Message 3 of 5
mumugalou
I'm using web interface
Message 4 of 5
CrimpOn
Guru
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 967 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
