- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Orbi RBR20 is blocking HomeKit
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20 is blocking HomeKit
If you have any PF configurations enabled, uPnP should be disabled...
@chrisbrummel wrote:UPnP is on, but it also looks like there's some port forwarding going on. Attached are 2 screenshots
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you restart the RBR as well after uPnP was disabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@chrisbrummel wrote:.....
Here's all that I'm forwarding:
- 192.168.1.253
- 8123
- 51829
@chrisbrummel Is the 51829 is the configured default port number in configuration.yaml in the Pi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@chrisbrummel wrote:...........
....... why people are recommending port-forwarding, since this is all within the network and not dealing with outside inputs.
Because Homekit -like most Apple or Google services- is a cloud-based service and devices need to be connected to internet to be able to make those features/services work. That's why a port needs to be opened on the router's FW to allow access of the devices to the cloud.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sadly, I still think I’m at a dead-end with what I know…
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Please try to change port 51829 to 51827 (tcp)
- You also need ports 8123 (tcp) and also 5353 (udp) for Home Assistant interface and mDNS respectively. I see that you have 8123 forwarded, but not 5353? Please try this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ekhalil — On the Orbi, I changed it to 51827 (tcp), and opened up 5353(udp). On Home Assistant, I updated the config for HomeKit to call out "port: 51827". I made sure that the Home.app was "opening fresh" and checked out the devices — "No Response" 😕
- Mark as New
- Bookmark
- Subscribe
- Permalink
- After making changes in the Home Assitant, I don't think that changes will take effect "dynamically", I believe that you might need to restart the Home Assitant service and may be the HomeKit devices need to be restarted as well.
- Do you have Armor (Bitdefender) enabled in Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. I restarted Home Assistant to have the config enact the changes. Is there something more to do on that end? Should I also restart the Apple TV hub?
2. I do not use their "Armor" service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes please, restart the Apple TV hub.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Restarted the Apple TV — "No Response"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Progress!! I updated the firmware to 2.3.5.36 - Hot Fix and I now have gone from 0% reliability to 66%! About 1/3 of the time, I get "no response", but this is a huge improvement. It also tells me that it's likely specific to the Orbi.
Thanks!
-Chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you ever find the solution? I am having the exact same issue. I had a working setup but, I had poor wifi signal so, I picked up an RBR50. Now I have the no response issue like you. I have tried all the same fixes you did to no avail. I am running newest firmware 2.5.1.8 and can't get it working. I think I'm going to have to dump the Orbi if I can't get this working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No solution. It's only gotten worse since my last message. It's not just Home Assistant that seems to have issues. My network, in general, seems to have better range, but create more issues in general.
- « Previous
- 1
- 2
- Next »
