Orbi WiFi 7 RBE973
Reply
Orbi RBR20 wifi drops in and out after update
missourimace
Follower
I have had my RBR20 for a couple months. It seems to work fine but then the wifi just drops out and everything connected to it drops out. I had a trouble ticked but I didnt realize they had time limits on customer service. I started a new case. I updated the firmware to v2.5.1.16  even though when I asked the system said it was up to date. I connect my pc and updated manually. My internet just drops and then reconnects? I had charter/spectrum out today and they can find  nothing wrong on their side. I drop in and out on voice conferance calls as well through goto and zoom so I have to dial in on my cell phone. Sorry just super frustrated with this wifi.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi RBR20 wifi drops in and out after update
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 265 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
