- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR40 Router and RBW30 Satellite - Router reboots itself randomly several times a day
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I've had the Orbi RBR40 Router and 1 x RBW30 Satellite for almost 2 years and recently (in the last 3 days) the router has been rebooting itself regularly throughout the day (5-6 times per day) and causing the WiFi to go down (it reboots and corrects itself within 5 minutes usually).
Never had a problem with them until now, but the major thing that changed is I am full-time working from home because of the COVID-19 pandemic (I'm based in Berlin, Germany).
I tried factory resetting them and they report being already on the latest firmware. Here are some further details:
Orbi RBR40 Router: Firmware V2.3.5.30
RBW30 Satellite: Firmware V2.3.0.4
Apartment Size: Approx 65sqm
Orbi Router is connected to a FRITZ!Box 7362 SL modem/router (this is plugged into the wall and recieves the internet but does nothing else, WiFi is off and this setup has worked for 1+ years without issue).
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm trying running without the Satellite for a while and see if it makes any difference 🤷♂️
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR40 Router and RBW30 Satellite - Router reboots itself randomly several times a day
After running without the Satellite for a few days, I can say the situation has improved greatly, I've had no reboots (which is a huge relief after a week of reboots every hour or so and trying to work from home) ... but now what do I with the Satellite? 😞 I'm out of warrenty and not really sure what could be causing it from the Satellite end - Already tried a factory reset ... anyone else have an experience like this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
