- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 Router has RED dot while satellites are both GREEN
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have wifi internet access to many of my other devices however both my Google Nest Hub and Amazon Echo Show will not connect, any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 Router has RED dot while satellites are both GREEN
Modem you're using?
Firmware on the orbi?
What errors is it giving you?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem: Calix GigaCenter m/n 100-04015
Version: 2.3.30
The error I am getting is internet is offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you powered OFF the modem/ONT and RBR for 1 minute, then back ON with the modem/ONT and let it sync then power ON the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this the one?
https://www.drtel.com/media/1382/844e_gc_ansi_product-datasheet.pdf
seems like it has an integrated router as well. That'd put you in a double nat and show no internet if both are running in router mode.
https://kb.netgear.com/30186/What-is-Double-NAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@joeb1970 wrote:
That appears to be the correct router provided by my satalite internet provider. In addition I think you are onto something what is the best way to solve this issue? I need the range of the orbi but I need the router from the internet provider so they cam control my land line phone?
