- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 Slow WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
xfiniti Xfi modem/router in bridge mode, service is 600 Mbps
RBR50 with one satellite in router mode connected to modem via Cat6 cable.
Doing speed test with Samsung S10 via Ookla app I get 250-290 Mbps
Orbi app shows v2.3.5.30
Why am I not getting full speed?
if I turn on WiFi on Xfi and connect to it with my Samsung S10, doing a speed test with Ookla app I get 560-600 MBps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 Slow WiFi
Has a factory reset and setup from scratch been performed since last FW update? Power OFF The ISP modem for 30 seconds then back on then walk thru the setup wizard after doing a factory reset?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Be sure your connected to the RBR when wireless speed testing. Turn off the RBS temporarily.
Download WiFi sweetpots on your phone to check to see the connection rate of your phone connected to the RBR. This shows just the connetion rate only. Not a speed of data flow.
@LuisJAbellon wrote:xfiniti Xfi modem/router in bridge mode, service is 600 Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see 2 problems here:
xfiniti Xfi modem/router in bridge mode, & Orbi app shows v2.3.5.30
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, reste has been performed.
House is 5000 SqFT and I have coverage throughout
Roter to satelite is 31 feet and I get BLUE connection
Channels are on auto....will try changing.
Will disconnect satelite fo rnext speed check.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why is xFi on brdige mode an issue?
Why is teh latest verssion v2.3.5.30 an issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@LuisJAbellon wrote:Why is xFi on brdige mode an issue?
Do a search in this forum. Numerous posts about problems with v2.3.5.30.
Most will agree IF possible, it's best to run the Orbi router with no other routers. Do a search.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ISP modem/router is on bridge and WiFi radios are turned off.
Orbi is in router mode.
connected with Cat6 cable, 6 feet apart.
service is 600 Mbps......speed test max is 300 Mbps, connected to base in the 5 GHz band.
i have rebooted both units.
Where red is my speed going?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If version currently used is a problem, what version should I use?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ISP unit is running in bridge mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, Tried everything suggested.......moved ISP router (in bridge mode) 8' appart.....connected to Orbi with Cat6 cable......I see no improvement.
Now I have ordered a CAT 8 cable......next will be to use ISP touter as router and Orbi as AP.
Any other suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@LuisJAbellon wrote:Hello, Tried everything suggested.......moved ISP router (in bridge mode) 8' appart.....connected to Orbi with Cat6 cable......I see no improvement.
Do you need the ISP router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No. I have the ISP router. Wireless and wired connection from ISP router shows speeds of over 500 Mbps. I have 600 Mbps service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@LuisJAbellon wrote:No. I have the ISP router. Wireless and wired connection from ISP router shows speeds of over 500 Mbps. I have 600 Mbps service.
Can you run your network WITHOUT the ISP router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ISP Router/Modem is the Gateway to the internet. Running in Bridge mode. Orbi runnig in Router mode.
So, no, I cannot access the internet without it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyone, will I get faster wifi speed if I run the RBR50 in AP mode? And allow the ISP Gateway to be the router? Obvisouly, I will turn off the wifi on the ISP Gateway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please give this a try and let us know if the speed improve. Yes configure the ISP modem for router mode with wifi turned OFF and configure the RBR for AP mode. I would leave OFF the RBS for now and just test the RBR alone.
@LuisJAbellon wrote:Anyone, will I get faster wifi speed if I run the RBR50 in AP mode? And allow the ISP Gateway to be the router? Obvisouly, I will turn off the wifi on the ISP Gateway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Please give this a try and let us know if the speed improve. Yes configure the ISP modem for router mode with wifi turned OFF and configure the RBR for AP mode. I would leave OFF the RBS for now and just test the RBR alone.
I already suggested this........hey welcome back!
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
