Orbi WiFi 7 RBE973
Reply
Orbi RBR50 VLAN setup
gooders
Hi there
I'm trying to connect my Orbi RBR50 to my new FTTC NBN connection (with TPG).
I need to change my VLAN settings to do this.
But when I try to follow the instructions for this in the manual...
"Select ADVANCED > Advanced Setup > VLAN/Bridge Settings"
There's just one problem...there's no VLAN/Bridge Settings tab there!
I've looked all over for it, but can't seem to find it.
Any ideas please?
Thanks
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
CrimpOn
Guru
Re: Orbi RBR50 VLAN setup
VLAN / Bridge is the very bottom menu item.  On my PC, I have to scroll down to find it.
Message 2 of 6
Guru
What browser are you using? Try a different browser?
@gooders wrote:
Hi there
Any ideas please?
Thanks
Message 3 of 6
gooders
Was using safari, but changing to chrome the option is now there!
Thanks v much for your help!
Message 4 of 6
gooders
Thank you! But it seemed to be a browser issue...all sorted now.
Message 5 of 6
Guru
Glad it's working now. Please mark your thread as solved so others will know. Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3792 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
