Orbi WiFi 7 RBE973
Reply
Orbi Router RBR20
kes_vas
Follower
Orbi Router RBR20
Hi ,We have  RBR20 Router and 2qty RBS , some of the location we can't get wifi signal.so we need to add RBS 20 in additional.
How many RBS we can Add in this Router?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi Router RBR20
I
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 409 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
