- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Satellite dropping connection regularly
- Mark as New
- Bookmark
- Subscribe
- Permalink
My question: how do I go about diagnosing how to figure out the root cause? Not sure if it’s the nest camera or the new orbi (when the nest was on the Apple WiFi I got no notifications so I suspect it’s the orbi)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Satellite dropping connection regularly
Potentially could have been an update to the nest camera as well. I had a thermostat that would go offline daily for a coupe minutes and reconnect on its own. I thought it was my orbi as well and changed it out for another router and it would continue the same routine. It did it for a couple months until the firmware on the thermostat was updated.
Couple things you could try though.
1. Assign it a static IP/reserve its ip address
2. Check placment of your router/satellite. If its right in the middle it might be dynamically switching from one device to the other or potentially switching bands. When it does this, some smart devices register as offline and send the notice.
3. another thought is if you have auto on for your channel selection. It could be switching wifi channels and the camera drops off during the switch.
Does it automatically reconnect or do you have to reboot it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@pugcoin wrote:
Upgraded from Apple to orbi about 3 mo ago - wow! The speed increase is amazing. One downside though is my nest Hello camera loses WiFi connection pretty regularly over the last few months....every 1-2 weeks (attached is screenshots of notifications).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Going to be buying Google WiFi and return the Orbi to Costco.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good luck in your endeavours.
My Orbi is working just fine. So are many others.
@richvohra wrote:
Been dealing with the same problem for months and there is no solution. There are so many people with this problem and no solutions in sight.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suspect it was the Nest Hello. I did a reset on the Nest unit and have not had any drops since.
Good luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will try some of the suggestions here and I hope it works
Netgear support doesn’t know what to do
I feel like people here are more knowledgeable
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try some of the suggestions I posted.
Give feedback to the question presented so we can get an idea of how your system is all set up and placed. All feedback helps us understand what you have going on.
Can try reverting FW versions as well to see if this helps.
@richvohra wrote:
Thanks for the update
