Orbi WiFi 7 RBE973
Reply
Orbi Satellite will not reconnect unless I disconnect all ethernet devices first
jblack68
Apprentice
Hi,
I have recently figurered out why my Satellite will not reconnect to my Orbi Router because there was ethernet devices connected to the Satellite - once i removed them and rebooted Satellite - connects fine.
Anyone had this issue before - if i disconnected Satellite and it will try and connect but would be listed as *Attached Devices* on the Orbi Page and Speeds will be limited to 10mbps
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 2
Guru
Re: Orbi Satellite will not reconnect unless I disconnect all ethernet devices first
What FW is currently loaded?
What LAN devices do you have connected to the satellite?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1299 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
