- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi and Epson XP620
- Mark as New
- Bookmark
- Subscribe
- Permalink
Everythings working great with new mesh/satellite- except my Epson XP-620 doesn't even see the router as an option to connect to. When I do the wi-fi wizard it only brings up the old router as an option.
FYI phone and Roku are set up feet away and get full wifi signal.
Appreciate advice.
I did see similar posts but most were older and didn't mention the 'not even seeing the router' problem.
Thanks,
Sean
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's resolved.
I reset the printer to original the original network settings, and a bunch of routers (including the key one) showed up.
No idea what was actually the problem, but this worked.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi and Epson XP620
A couple of options:
When going through the Wizard, press the cancel button when you do not see the network, scroll through until you see "Other Networks" and OK it. and proceed to manually enter and log in.
If the above does not work, delete the software for your printer on the computer where it resides, then go to epson download site and reinstall the software and start form scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What WPA security modes are you using? Try WPA/TPIK first to see if it will connect then try WPA2 and AES only.
Appreciate advice.
Thanks,
Sean
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think the issue is that Orbi is transmitting on 2.4 GHz wifi channel that the printer does not support. If you have set the 2.4 GHz to Auto then it can be that Orbi is using channels 12 or 13,..... which many devices don't support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this? Let us know
Epson Network Interface Specifications
Wi-Fi
Standards | IEEE 802.11 b/g/n |
Security | WEP (64/128 bit)
WPA-PSK (AES); complies with WPA2 with support for WPA/WPA2 Personal |
Frequency range | 2.4 GHz |
Coordination modes | Infrastructure mode
Ad hoc mode (not supported for IEEE 802.11n) Wi-Fi Direct (not supported for IEEE 802.11b) Note: Simple AP mode is compatible with Wi-Fi infrastructure mode.
Appreciate advice.
Thanks,
Sean
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's resolved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possibly something in a bad state on the printer. Glad the reset worked for you.
Please mark your post thread as solved so others will know for future reference.
Enjoy.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
