- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi and Google websites
- Mark as New
- Bookmark
- Subscribe
- Permalink
'm at wits end and hope that someone here might be able to help.
I have an Orbi20 with two satelites. I get great speeds (~200mbps) and have been very happy with the device. Over the last few weeks, I have noticed that all Google owned properties (Gmail, Drive, YT, Search) have been incredibly slow, sometimes not even able to load. I have tried, multiple accounts, browsers, computers and nothing changes. When I take my laptop outside my home, everything works fine. Come back home and the slowness re-appears. I contacted my cable provider, reset the modem and router, changed the DNS to 8.8.8.8 and then 1.1.1.1 and nothing. Again, this only impacts google properties and nothing else on the internet. Fast.com consistently gives me ~200mbps.
I finally tried connecting directly to my cable modem and guess what, google worked normally! Went back to connecting via Wifi and we were back to slow speeds. Contact Netgear and they were no help. They seemed unable to comprehend the problem.
So now I am trying here. Help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi and Google websites
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What other type of devices are connected to your network? Perhaps something else is causing this behavior.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same exact problem, have troubleshooted the exact same steps, and I'm at my wits end. I can't understand why or how this is happening. I disabled QoS and WMM in attempts to resolve and tried a whole slew of different DNS providers, but can't seem to resolve. If you find a solution please do follow-up with us here!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router RBR40 V2.2.1.210
Satellite RBW30 V2.2.1.204
Both wired and wireless clients experience this problem. Have tried Quad9, ISP DNS, Cloudflare, Google DNS, etc.
Have tried with QoS and WMM enabled and disabled in every combination. ISP is RCN and RBR40 is in router mode connected to our modem which is Arris TM804G. Every other site / service performance is perfectly fine except every and all Google related services.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connect up one wired PC or laptop directly to the ISP modem. Do you get the same issue with google?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, directly connected everything loads perfectly fine and performance is as expected. Please trust me when I say I've ran through every single plausible scenario to rule at an issue other than it being the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, it wasn't mentioned that direct with modem was done so reason for asking.
I would do this, upgrade to v32. You'll need to download v212 and v32 for the RBR. Download v32 for the RBS and apply this first. You don't have to apply v212 to the RBS. Then apply v212 on the RBR, then apply v32.
I would power OFF the ISP modem for 30 seconds as well. Do a factory reset on both RBR and RBS and setup from scratch. I would not add the satellites just yet.
Use a wired PC and setup the RBR first. I would set the LAN IP address range to 192.168.1.100 to .200. You can make the pool size even smaller if you don't have that many devcies, say .150.
Set up custom DNS for 8.8.8.8, 8.8.4.4 or 1.1.1.1 and 9.9.9.9 or leave DNS at auto.
Save settings and fully reboot the RBR. When the RBR is rebooting either reboot the PC or do a IPCONFIG /flushdns in a command line box.
Besure to clear ALL browser caches, close the browser then reopen and test internet connections and services.
Let us know...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the help so far. Do you know why v32 and v212 don't show as available updates through the web interface? Interface is reporting both devices are up to date so I didn't even go out of my way to check for manual updates on either device. This is powering a small business network so I don't have the flexibility to run betas unfortunately.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You maybe in a region where your system isn't avaialble on the servers as of yet. Manual update is preferred however. Please use IE11 or FF browser to perform the FW loads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netegear support page claims v32 is for the 50 series only. I'm on an RBR40.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oops, sorry about that...should have checked your model, for 40 series, please use the v28 version that is available.
