Orbi WiFi 7 RBE973
Reply
Orbi iOS app not showing correct network mapping
Buko
Hello,
i am facing some strange problem, as you can see on a photo there is my network setup showed on android and ios, but the way android shows is is correct. Why iOS app is not showing my 3rd sattelite? I checked on router webpage in Attached devices that "Orbi Kotlownia" is connected with 5G to "Orbi Pokoj 4" with Good signal. Router is set in AP mode, but i think it doesn't matter since it shows good in android.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi iOS app not showing correct network mapping
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 452 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
