- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi is connected to internet but devices won’t
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi is connected to internet but devices won’t
There are many models of Orbi's -- each with their own version of firmware etc.
Could you describe what model of Orbi you have, how many satellites, and what is the make/model of the device (modem) you are trying to connect your Orbi to? Is it a modem/router combination? If so, what mode is your orbi operating in? (ap or router)
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
@Jmilla74 wrote:
I bought an orbi In November 2018. It seems like every 3 weeks like my orbi doesn’t allow me to use certain apps on my phone or allow my PS4 to connect to the internet. These devices work when I connect to my isp modem WiFi. Does anyone know a solution to this problem? I also tried a new setup. It used to work but now it doesn’t.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That the modem provides wifi suggests that it may also be a router. So the question about the modem from @Chuck_M may be important. Also, is the Orbi in router mode or access point mode?
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
When replacing bits of a network, you also need to tell the existing bits to forget any bad habits they picked up from the old hardware. The way to do this is probably to factory reset your Orbi, and the start the network in the recommended order, and set up the Orbi from scratch.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
You may have done all of this already, I can't tell from your message.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
