- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi setup: AC2200/RBK30 connecting to netgear modem CM500
- Mark as New
- Bookmark
- Subscribe
- Permalink
Internet provider: Spectrum Xfinity cable
Cable modem: Netgear CM5OO
WiFi router: Netgear N600WND R3400
I just bought an ORBI AC2000/RBK30 and followed the orbi setup instructions. My iphone could not recognize the orbi device to complete the set up. This is what I did so far... Should I set up using my laptop hardwire to ORBI rather than thru my iphone ?
- disconnect my netgear wifi router from modem
- hook up orbi to my modem
- download orbi app from apple store
- turned on my wifi on the iphone
- got a message saying ORBI device not found.
Should I set up using my laptop hardwire to ORBI rather than thru my iphone ? Please help! Any advice is appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi setup: AC2200/RBK30 connecting to netgear modem CM500
Use a wired PC and web broswer pointed to 192.168.1.1 and setup the using the RBRs web page.
Review the installation guide PDF as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, using a computer connectee to the router's ethernet port and using the Orbi's web interface is the best way of setting things up.
How do I set up my Orbi router and satellite?
My preference in in red in Steps 10, 11 in the above link:
- Connect your computer or mobile device to the Orbi router or satellite with an Ethernet or WiFi connection.
Note: To connect with WiFi, find the preset WiFi network name (SSID) and password on the label on the Orbi router or satellite and connect to that network from your WiFi-enabled computer or mobile device. - Download the Orbi app or visit http://orbilogin.com to set up your Orbi WiFi network.
The Orbi router's ring LED turns off after the setup is complete.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it looks like you have 2 routers in your system? Is that true?
if so perhaps these will help
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
- Mark as New
- Bookmark
- Subscribe
- Permalink
Remove the R3400 router and use the Orbi router as your main host router.
@ChangXray wrote:Internet provider: Spectrum Xfinity cable
- Mark as New
- Bookmark
- Subscribe
- Permalink
To: Vajim,
Here is my response. . .
- No, I do not have 2 routers, I am disconnecting the N600WND R3400 and connecting my ORBI to the modem.
Thanks,
